I'm starting this thread to see what breaks in these transmissions and what everyone is doing about it. What have you broke? what hp are you at? rpm? when did it break(during 1-2 shift..etc.)?
I'll start with mine.
On my STOCK 2000 z28 running low 13's at 3400lbs trans had 105,000 miles on it before it started slipping on the 1-2 shift...but this was after a full summer of about 40 passes at the track..much more on the street.
Had a Local shop rebuild it with a B&M shift kit, beast shell, billet 1-2 servo...with a stock converter the tranny would shift super hard into 2nd...leaving 10ft posi marks everytime...after about 2 months it started slipping the 2-3 shift, then shortly after that I made a hard 1-2 shift and it broke the output shaft!!!! Only at 305hp running 12.7's with 3.73 gears. I then later found out that the B&M kit is a joke and in the instructions they say to add spacers to the 1-2 acc. to get the harder shifts...
Next build....So I added a 2800 stall, rebuilt the transmission(myself), added a transgo kit with stiffer acc. springs, the HD pump slide spring, trans shifted great for 2 years now running mid 11's ....I think the converter helped the output shaft by taking weight off of it during a shift and the better shift kit with acc. springs helped as well, and I think the HD pump slide spring kept pressure up at 6,000+ rpms for the 2-3 shift.....at the end of the 2 years I added a LS2 with a bigger cam,,, went back to the track ran a 10.9 shifting at 6,600rpms....next pass it POPS out of 2nd gear HARD...I ended up tearing the trans down to find a badly brused forward sprag..this was the dual cage sprag...I later found out that racing in the OD position does NOT apply the overrun clutch...Racing in the D position applies these clutches and can help support the sprag, I just replaced the sprag and have been running low 10's on a 75 shot racing in D and have not had another sprag issue YET.......
Now I have a 4l60e in the LS1 Dodge Ram with the beast shell, dual cage sprag, and corvette servo with the stiffer 1-2 acc. spring offered by (PATC.com)
From what I have learned you need a decent quick 1-2 shift without BANG shifts, it seems this breaks parts, the 2-3 shift I have only had clutch issues with...but once I added the HD pump spring to the pump it seems to remedy this. I have not added a shift kit or hd pump slide spring to the Ramaro yet, but before I go turning up pressures I want to see what parts are holding up or breaking in the 4l60e when behind a 5,500lbs truck...
