Page 6 of 19 FirstFirst ... 4 5 6 7 8 16 ... LastLast
Results 51 to 60 of 182
Thread: 5.3 in ranger?
  1. #51
    Oct 2009
    Quote Originally Posted by danger_ranger83 View Post
    what kind of truck?
    1996 ranger 2wd 4 cyl 5 spd just curios what stock rear ratios are.
  2. #52
    Dec 2009
    my 4l80 has a busted bellhousing do u have everything with the 400 to make it work with an ls motor?
    What a shame.
    I have no idea what it takes to put a Turbo 400 behind a LS1 style motor. Do they have the same bolt pattern as an old SBC?
    Since your 4L80 has a broken case I'll probably pass.
  3. #53
    Feb 2010
    Odessa, texas
    Quote Originally Posted by fastlt1 View Post
    im pretty sure all 4 cyl rangers came with 3.73s
    1983 Ford Ranger- 2.3 to 205k mile 6.0 swap
  4. #54
    Feb 2010
    Odessa, texas
    Quote Originally Posted by Fasglas View Post
    What a shame.
    yea broken bellhousings make me sad ....bolt patterns are the same just need a converter to bolt up to an ls flexplate
  5. #55
    Mar 2007
    Newark, Delaware
    What year 6.0 did you get? Since it has iron heads it must also have the long rear crank snout. That means a Turbo 400 should bolt up no problem.
  6. #56
    Feb 2010
    Odessa, texas
    Quote Originally Posted by Beatdown Z View Post
    its a 99 and your right i didnt even think about that....
  7. #57
    Feb 2010
    Odessa, texas
    i think i might be able to get the motor to sit far enough down in the frame with these mounts
    the shiny thing is my new/stock/ford oil pressure sending unit
  8. #58
    Feb 2010
    Odessa, texas
    coolant temp sensor...right above the starter
    this is good enough isnt it?
  9. #59
    Dec 2009
    Thomasville, ga
    i wanted to 2jz swap a ranger last summer. lol
    1984 c10-its an old truck with an LSX
  10. #60
    Dec 2009
    Quote Originally Posted by bk_cauley View Post
