Page 6 of 16 FirstFirst ... 4 5 6 7 8 ... LastLast
Results 51 to 60 of 152
Thread: weight reduction 101
  1. #51
    Roma, Texas
    Always Race A Truck That Is In Your Weight Range. I Here Nnbs Are Heavier Than Nbs. The Older The Truck The Lighter It Is. We Are Going To Build A 72 Swb With Fiberglass Front And Well We Already Have Marillitas Step Side Bed. Its Hard To Tear Up A Nice Looking Truck Like Yours, So Get A Project Truck And Strip It.
    [CENTER]
    GLADIATOR 6.0 2007 nnbs chevy 13.2 1/4mi. busting my drive shaft at 106 mph before the finish line
    CHEATER 6.0 2000 gmc xcab lq9 fully bolt on 12.52 motor and 11.62 n2o.
    http://youtu.be/UV-I1mlKcTI
  2. #52
    Aug 2005
    St. Anthony, Indiana
    Quote Originally Posted by oleshifty View Post
    for those that removed the spare crossmember...
    (i have a body lift and spare hangs below bumper, it's ugly anyway and I want a fullsize mounted to my rollcage)
    how did you remove it? It looks like it has to be cut out. How much did it weight? If it was an unbolt, put back to stock later, i'd do it for a 20lbs saving. If i have to permenantly cut it out...it better weight over 100lbs.
    Thanks.
    you shouldn't have to take out the whole cross member. My spare tire hanger was bolted to a plate attached to the crossmember.
  3. #53
    Plainfield, IL
    that plate can't weight more then 10lbs... not worth the effort.
  4. #54
    10 pounds is a hundredth of a second
    zach, if youre ever my around my truck just take a look, also underneath theres a few things, my truck was at dbrods on the lift this weekend and jon says now i know why this thing wieghs 3900lbs
  6. #56
    all i need is a plasma cutter lol,,sawzall aint cutting it!!
  7. #57
    New Orleans
    how much will it affect the frame strength if you remove the trans cross member and all those tubular supports?
    07classic
    !MY GARAGE!
  8. #58
    i was playing around,u dont want to take off your trans crossmember lol
    well on my old truck ,sice it was bagged i gutted fenders etc,as for the rear i cut off the spare tire bracket since i was running a 2link
  9. #59
    New Orleans
    i have 4 tubular supports that are bolted to the bottom the the rails, how beneficial is it for those to be there?, they don't weigh much but every lb counts
    07classic
    !MY GARAGE!
  10. #60
    yea on yours u can cut off the ones that dont hold the shock mounts.
