Skills!!!
nice work! that obs looks factory with that airbox routed like that
92sierra is back for some go fast mods. Here are some more pics. Thanks beatdown and myzterray!
you do some great work. keep it up.
single digit street truck
for build info
Did you make the pcm mount for the 92 Sierra? Clean installation, looks like it came from factory.
Thanks y'all! The pcm mount is an oe piece from a 99(I think) Isuzu Rodeo. Turned out to be a nice fit.
Go fast parts? Such as? Haha we are so detail oriented around here![]()
Sending the 317s to Advanced Induction for cnc porting and a compression bump along with a cam, spring, pr, and retainer kit. Don't know any specs yet. Build the rear: Yukon 3.73 gear set, master kit and Trutrac. Shoenfeld LTs, still trying to talk him into dual 3" Magnaflow. He's afraid of cab drone at cruising speeds? Either way, the exhaust system will be mandrel bent and Tig welded. Also likely a Circle D. Already got it torn to pieces, lol. Once im done with it, ill run it over to my boys @ Injected Engineering for a dyno tune.
Wow ! Nice clean work ! If mine turns out anything near that clean ill be happy.
