Page 5 of 6 FirstFirst ... 3 4 5 6 LastLast
Results 41 to 50 of 52
Thread: 370 Nissan Hardbody
  1. #41
    Dec 2003
    Newark, Tx.
    starting to get going again.
    Picked up a Bullet cam today.
    256/258 .630's 114lsa.
    Should be interesting.
  2. #42
    Houston
    did u decide to put the bigger motor in the hard body i hope? and not the other way around like you were thinking?
  3. #43
    Dec 2003
    Newark, Tx.
    yes, I'm sticking with my original plan and doing the 370 in the Hardbody.
    Not sure if I mentioned it, but I picked some Trevor Johnson ported heads with bigger stainless valves too.
  4. #44
    Dec 2003
    Newark, Tx.
    Quote Originally Posted by Defunct SO View Post
    Correction- bought the cam used and was told the wrong specs. Called Bullet today and the correct specs are
    244/252 .638 on a 115+4.
    Still should be fine.
  5. #45
    Mar 2006
    Mesquite
    Looking forward to the finished product.
    Move closer so I can come help!
  6. #46
    Dec 2003
    Newark, Tx.
    Got my Melling oil pump and Edelbrock 2 piece timing cover today. That timing cover should make cam swaps much faster.
  7. #47
    Made any progress on it other than acquiring two parts?
  8. #48
    Dec 2003
    Newark, Tx.
    cleaned a little more and got rid of a few more parts off of it.
    Work is slow, so everything else that has to do with extra money is slow too.
  9. #49
    Aug 2010
    Cannon Falls Mn.
    Gonna be badass
    99 4x4 5.3 NELSON TUNED / 02 Ls1 CAM / 02 Ls1 "241 Heads" Port/Polish milled .045" / 03 INJECTORS / AIR RAID JR. INTAKE / PORTED THROTTLE BODY / TR55's / EGR DELETE / E FAN's / CAT DELETE / EXHAUST DUMPED
    Headers, Transgo HD2, 3200 stall, 4.56 gears coming soon.....
  10. #50
    Dec 2003
    Newark, Tx.
    Got a little more done. Engine is sitting basically in place. Its on stands and truck is on dollys so I can roll it around.
    Going to borrow some F-body long tubes to check and see how close they would be to working.
    There is a crossmember below the engine that will have to be remade to fit.
    Will need to use a pusher fan as there is only about an inch between the waterpump and radiator.
    I know the heads are nasty. They are just for mock up. Also will be using the Vic Jr., not the LS1.
