Save yur pennies ,deck are expensive also nowadays.I have a multilevel deck 120 ft long and wrapped around the pool also ,i built it and i still spent 20 k.choose your material wise ly.most of it is garbage and youll be replacing half of it in the first year.threyres some real good composite railing and materials but do youre research,b4 you buy them,theyres many and some of thhem are junk also .
