Page 4 of 10 FirstFirst ... 2 3 4 5 6 ... LastLast
Results 31 to 40 of 94
Thread: Alternative turbos...
  1. #31
    becareful now. Those on3 turbos have a really small exhaust exducer. Its only 65mm. So that is going to limit high rpm power anyway. If I were building it I would go with a 76mm with the 1.0 divided housing. Thats what Im running on mine and I dont have any problem spooling it. Your truck is a good bit heavier than mine and being you have a 4.8 your motor is going to have more load on it all the time to get your heavier truck moving. I doubt you would have any problem spinning that turbo and making some low end torque. Now the 70mm should come on a little sooner, I just dont want you to be running out of steam too soon
  2. #32
    Sep 2011
    Tell me a lil more specs on your engine and tranny set up.
  3. #33
    Sep 2010
    North East Ohio
    Stock 2010 4.8 block with 210/224 112 vvt cam , compression I believe is 9.1 for this years engine, trans has converter that seems to stall around 2600-2800, 3.42 gears 4x4
    2010 Silverado 4.8 Ext Cab 4x4
    Cam, Stall, 4.88's
  4. #34
    Sep 2010
    North East Ohio
    Also what size oil fittings are you guys using? -3 in -10 out or are you using -4 with a oil restrictor?
    Cam, Stall, 4.88's
  5. #35
    I would think your CR is higher than that. Do you know your engine code? And Im running a -3 feed and -10 return with no restrictor and no problem.
  6. #36
    well Gus, it looks like you are right. Sorry about that. Thats crazy that they are only 9:1. Should be able to throw more boost at it now
  7. #37
    Sep 2010
    North East Ohio
  8. #38
    Sep 2011
    I work in a hydraulic shop so I used what was free. 1/4 inch hyd hose no restrictor and a 1/2 inch hyd hose for return. I have a small 1x1 inch resivor about 5 inches long under my turbo the 1/2 inch hose connects to.
  9. #39
    Sep 2010
    North East Ohio
    Being that my compression is low and the sizes are a bit smaller for this brand what are we thinking on the ar. Looking for Low to mid range power, .68,.81,.96 I would like it to be pretty close to full boost when my converter is past the stall point.
    Cam, Stall, 4.88's
  10. #40
    Maybe a 76mm with a 81 ar
