Results 31 to 40 of 58
Thread: supercharger/nitrous and more
Threaded View
    Jun 2007
    lower price supercharger/nitrous and more
    Well ive decided im going back semi stock for the winter then front mount turbo so here it goes.yes ill get pics in today sometime.ill try to be as fair as possible on pricing ,ive just got a crapload in all this.
    heck with it ,MAKE OFFER ON ALL THIS STUFF GUYS<GET ER DONE
    2.Band M supercooler pt num 70266 brand new $50.00
    3.proffesional products fuel rails.with an crossover and ls fuel line adapter.$75.00 tried installing them without success ,dont remember why ,no fuel through them tho.
    5.i also have a comp cams vaccuum resavoir $50.00 black
    plus i have a complete aeromotive fuel system ,reg, eliminator pump,pump controller,100 micron ss filter with many fittings .$500.00 nice stuff ,the ss 100 micron did peel though ,probly the salt up this way.i will break up the kit and seperate these parts.and aeromotive 1 way check valve ,black in color
    i have tons of a/n fittings like the ls fuel line adapter to go from -8 to factory fuel line ,never used ,make offer,and lotts of couplers,swivels , aeromotive one way check valve .etc
    Moroso catch can ,single -12 inlet with -12 barb fitting to fit russell push lok line all i did was come off both valve covers and y into 1 -12 line worked awesome. MAKE OFFER.
    I have a msd tach adapter pt number 8913 dis-tach driver
    Band M supercooler pt num 70266 brand new $75.00
    proffesional products fuel rails.$75.00
