Page 4 of 4 FirstFirst ... 2 3 4
Results 31 to 33 of 33
Thread: cam for a turbo motor?
  1. #31
    Oct 2006
    Wichita Falls Tx.
    There is a good difference between 6 and even 10psi. Turn the knob a little and keep watchin the air fuel and knock.
    just a thought. Cams are expensive in relation to turning a knob.
    Online Store
    [/CENTER]
  2. #32
    Winnipeg, Manitoba, Canada
    at 6psi that turbo is most likely below its efficiency range so i agree, 10-12psi should be do-able on pump gas on that engine with proper tuning and it would feel like a whole new beast.
  3. #33
    Oct 2006
    Wichita Falls Tx.
    yupp, turn of a knob is the best. go from 300hp to 800 in about .5 seconds
    Now that would be the nitrous bottle knob. I was refering to the boost controller.
    Online Store
    [/CENTER]
