Page 30 of 33 FirstFirst ... 20 28 29 30 31 32 ... LastLast
Results 291 to 300 of 504
Thread: Official NBS 4.3v6 to GEN 3 V8 swap Guide
    Jul 2013
    Very helpful thread to say the least..Is there any differences doing the same swap but using a 07 Escalade 6.2?
    Thanks
    Jan 2012
    DFW, TEXAS
    Quote Originally Posted by Jeff Hefler View Post
    Thanks
    what is it going in?
    Jul 2013
    Oh yea i guess that would help..Its going in a 2000 GMC half ton truck...I have bought the 07 6.2 and a 05 6.0 both out of escalades.
    Thanks
    Aug 2013
    2002 1500 4.3 60e sht bed std cab
    Jan 2012
    DFW, TEXAS
    same. 4l80 will mount about 7 inches further back than that 60e. but that swap has been done many times before. You would follow the sticky and use a v8 harness for a 2002 truck and then conversion box 24x-58x
    Dec 2013
    I've read over this thread and didn't see my question addressed. My truck is a 2002 4.3 5 speed 4x4. I know I need a harness from a 99-02 v8 truck as well as a new fly wheel and clutch, but does the harness have to be from a manual trans truck to avoid other issues?
    hot & windy
    finding a harness from a manual truck will be the easiest way, but you can use either. since you'll have the manual t-case, you don't have to worry about finding one with the electronic 4x4 wiring. also, if you use a harness from an auto, you can pull out the transmission wiring (with the exception of the VSS & reverse). click my sig to find the company i sent mine to (because i didn't feel like fiddling with it). it also shows the jumper you'll have to add to the fuse block for the clutch safety switch (which you can just reuse from your V6 harness).
    00 FRC - just top end, exhaust, and a hot-air intake
    99 Sierra - 5.3 / 5spd
    ↓ click the pic for the build ↓
    Dec 2013
    Quote Originally Posted by zebra View Post
    Thanks for the info. I read over your thread, and Current wiring is about 25 miles from me. Convenient. lolc
    No. Mine is an auto harness. It already has all the manual stuff in it, just shut off. Plug it in, program the PCM with a manual trans file. Drive truck.
    hot & windy
    funny... my harness came from an 01 Tahoe & wouldn't start until i figured out the thing with the clutch safety jumper. no power to the starter - just like trying to start without pushing the clutch pedal in.
