Page 3 of 3 FirstFirst 1 2 3
Results 21 to 26 of 26
Thread: couple simple questions
    Mar 2006
    Mesquite
    I I.M.'d Eric and asked him to come help you...he'll probably show in a bit.
    Apr 2003
    Mansfield, Texas, USA
    Cool
    You must go to a 130-145A with the e-fans or you'll tax the charging system too much. Those will put out about 55-70A at idle. The 105A does maybe 40-45A, that's insufficient for modification.
    If you wanted just pulleys OR just efans, you could use the stock 105A and be fine with only the OD alt pulley.
    The OD alt pulley from ASP is 1.75", this is the smallest you can purchase and will allow full charging at idle as alternator speed is up, not crank speed.
    Ideally you'd want this:
    E-fans
    ASP
    OD alt pulley
    130A + alternator
    16-18rwhp, full charging, more capacity, better cooling, slightly better economy.
    Oct 2005
    drinking your alcohol
    ok so all i need now is pullys and an alt..... its pay day soon, and i saw you have some stuff for sale...... what kid of UD pulley do you have and what size OD pulley would you suggest ......
    since i have a couple subs and just bigger speakers in general... should i go with the 160 or would the 145 be pleanty sufficient??
    DamnYankee: my nana failed
    Apr 2003
    <div class='quotetop'>QUOTE(TxStVanWilder &#064; Jan 10 2007, 05&#58;50 PM) [snapback]79170[/snapback]</div>
    It&#39;s an ASP, only ones made for the trucks. Very nice piece. It&#39;s the only alt pulley I sell with them, 1.75" for great idle charge.
    145A puts out a lot of power, the 160A needs a new plug and you have to do some trickery with the pulley.
    Jan 2007
    i should of read this post before starting a new one
    2001 silverado 4x4 ext. cab, 2006 front end, cold air intake, msd spark wires, flow master, hp tuning, 20" bbs rims, 2" drop in back, e-fans
    http://i134.photobucket.com/albums/q.../jaxbigger.jpg
    Oct 2005
    145 for a winnAr
