ok thanks. anyone else? ive read the 05 1 ton flywheel would work? Im just tired of pulling all this stuff out so I only want to do it one more time!!!
I doubt it. All the 6.0 trucks after 2000 had the offset flywheel. You need a flywheel for a 99-00 6.0
2008 GMC Sierra SLE....370ci LY6 with some goodiesSOLD
1995 C2500- LS1 swap with a mp112
build thread- http://www.ls1truck.com/forums/lsx-t...-ls1-swap.html
rock auto and advance auto doesn't show a flywheel for 99-00 6.0 engine. I found this http://www.jegs.com/i/McLeod/673/460530/10002/-1
they also show a .200 and a .400 thicker flywheel.
That looks the same as the ram 1550 flywheel which is .4" offset. You need one that has 0 offset
Not sure where I seen it but someone makes an adjustable internal throwout bearing that you might be able to adjust for your setup.
http://www.novak-adapt.com/catalog/c...t_bearings.htm
I think I have located 1 2000 model 6.0 flywheel from a salvage yard. its the only one in the us that they showed. so we will see how it works in a few days.
no go. anyone have a local salvage yard that might have a truck like this in it? I'm almost out of options i guess.
You can either swap cranks or buy a newer motor. That's about you only other options....![]()
Found a flywheel in cali that is "suppose" to be for a 2000 truck. They said it is not for the 01 and later. Got it bought today will see when it comes in.
