Results 21 to 30 of 52
Thread: The "help save my marriage" LSx swap!
Threaded View
    The "help save my marriage" LSx swap! 99 Tahoe 4WD 2dr LQ9
    Well, not really. But my wife is legitimately tired of being a garage/car widow. I'll spare you some of the details, but I've done some earlier upgrades where the time and $$ were far greater than anticipated. Such as this one w/my Cutlass (which I'm still working out a few bugs):
    http://ls1tech.com/forums/conversion...dayton-oh.html
    My current saga started when my daughter totaled our 2004 minivan Christmas Eve last year (best Christmas present was she and other driver unhurt--thank God). So I started thinking about a replacement utility vehicle and my wife was beyond the minivan stage of life, and I always liked the full size 2-door Tahoes, so I bought a rust free tahoe from California. I liked it as is, except I wanted a bit more power and fuel economy, so I upgraded the exhaust and went w/Mark VIII fans and 0411 ECM. The day after I got it home from dyno tuning new PCM, I was pretty happy--nice pep, great drivability and efans work properly. But that night driving home I get a "check gauges" light and have low oil pressure and then an engine noise. I don't know what, but something internal is messed up. Long story short--if vortec motor has to come out for any reason, an LSx motor has to go in!
    So I bought a 54k mile 2002 LQ9, and have been gathering parts and info to make this the quickest, easiest swap ever. Major goal is for wife to be amazed at how little time this takes: I want the actual swap of the engine to be over one weekend and some time before and after to button things up.
    So in pursuit of that I'm slowly getting everything I need, here is what I've done so far:
    Bought Beertester mounts to keep engine exactly in stock location WRT tranny
    Bought Lextech's accessory brackets
    Will send Lextech both my stock tahoe harness and the LQ9 harness for integration
    I'm picking up a complete 2003 LQ4 "core" that apparently won't run $200 today that has all the little things my LQ9 longblock didn't (starter, passenger exhaust manifold w/o EGR, downpipes, truck D535 coilpacks)--it was in an express van that rolled and the engine was not hit at all.
    Since LQ9 is out, I've been getting "must do" upgrades now, and I decided to get both a TBSS manifold and an LS6 valley cover. Anything else I should do prior to engine going in? For the manifold, I made a small bracket to mount the corvette fuel filter to the fuel line, and welded a bracket to convert the DBW to DBC and got a Ballistic Speed TB, and swapped my TBSS injectors for the stock LQ9 injectors so no changes to wiring harness needed. Only issue is the TPS doesn't tighten fully on the TB; I just unbolted from the stock TB and put it on--does it need a new gasket or something when swapping that will give me that little extra so its secure and tight?
