My bracket is just like the ones you guys used or the same as the Malibu site. That was standard on my truck as well. Don't forget, the V-6 and V-8 engines were similar in almost every respect except for 2 cylinders being lopped off. The bolt holes on the front of either engines were in the same location so one bracket could be used on either engine.
Fabi, I do recall going to the junkyard and scrounging a couple of idler pulleys from some GM V-6 cars. I physically measured mine and then went and found some slightly smaller ones so I wouldn't get any belt rubbage at the water pump pulley. Before changing idlers, my clearance might have been about 1/8" max. I found that to be a little tight for my tastes so I opted for a smaller pulley. By mixing an matching pulleys, I ended up with about 3/16" clearance and haven't had any issues.
Just for kicks, here's another pic of my bracket which was originally installed on my 5.7. It's laying on the cart with the 6.0.
John
