Results 21 to 30 of 36
Thread: Help with 5.3 Engine build in rock crawler
  1. #21
    I dropped the block and heads off today at Longs Machine. Can I do a .040 over without any kind of problems?
    87 Samurai 14b f&R 5.3/350/205 42s
    04 H2 NP tune 6" w/ 37s on 22x14s
    04 Dodge Laramie Cummins
    04 SRT10 w/twin turbo Cummins
  2. #22
    Pittsburgh, PA
    can go .120 but gotta becareful
    heres a little 53 I put together for my lifted jee
    http://www.youtube.com/watch?v=eXpA5...eNbygkIVUo4iFw
    GMT900 intake with 90mm tb, thumper 1 cam, ls3 manifolds with dual 2.5 exhaust, CAI this combo should make some decent rwhp for what I have into it
    specs are 219/233 553/537 109 lsa...using 08 injectors
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
  3. #23
    Where can I get a .120 over piston?
  4. #24
    Feb 2011
    Barnwell, SC
    .120 over makes it the same size as an ls1. Just look for ls1 pistons.
    99 Silverado 4.8l : Soon to be 80E swapped, then 6.0 swapped, ......
    05 Yukon Denali 6.0l : Nelson Performance Tune, ......
    8X S10 Blazer on a 8X 3/4 ton frame : 5.3l swapped, Nelson Performance tune, Schoenfeld LT's, 226/226 .598/.598 112, TH350, planetary doubler, NP 205, locker, spool, 38's, ......
    Quote Originally Posted by blacksss46 View Post
    couldn't agree more. its like boobs you'll get a C and end up wanting a D...just get the bigger one and be happy
  5. #25
    Are they a direct replacement after that? Pin height the same? Can I use the stock 5.3 rods and everything?
  6. #26
    What is the danger of going to a LS1 piston? Would I have rod concerns with that size piston on a stock 5.3 rod at 11:1 CR?
  7. #27
    bump....
  8. #28
    Sep 2011
    A 5.3, ls1(5.7), and 6.0 are all the same stroke with different bore sizes. A 5.3 block can be bored to ls1 specs. There are a lot more piston options for a ls1. Put the ls1 pistons on the 5.3 rods, rebalance and assemble. Its that easy!
    99 rcsb silverado...... boosted.
  9. #29
    Thanks man.
    I am going to buy HP Tuners to tune this setup, would anyone have a base tune to get me started they would share?
  10. #30
    Pittsburgh, PA
    all depends on what route you choose
    412 Motorsports
