Results 21 to 30 of 73
Thread: Conversion Progress Report
    Mar 2013
    Long Beach California
    you do have some "play" in the brake booster line right? to allow for engine vibration and movement when the throttle is punched??? thats why they are usually a rubber line.
    CALI LEGAL ENGINE SWAP!
    Aug 2011
    Ellsworth Air Force Base, SD
    Sure do, the connector between the line and check valve is a soft flexible connector hose.
    1994 Chevy C1500 RCSB 05' DBW 5.3 Conversion Complete
    My build
    Coming soon ....... Full Repaint, 214/220 Cam, Yukon Posi with 3.73's, remove body lift
    Oct 2013
    Jacksonville, AR
    I see someone has been hitting up the scrap pile from work....lol Yeah, that's VATS kicking in. Glad to hear that it runs though.
    Aug 2011
    Me too, with all this installing of parts, I forgot to add an air intake to my build. I could not find a drivers side CAI, so it looks like I will be moving the battery over to the drivers side. Got a smoking deal on this 4" Spectre cold air setup in town. Now too just move some wires and install.
    My build
    Oct 2013
    Jacksonville, AR
    Have you moved your battery yet? If you haven't I found out that you can use those 99+ CAI w/o moving the passenger side battary tray. Look up LT1swap on Facebeook and look at his 88-94 C1500 conversion and you can see how he positioned the metal tube.
    Aug 2011
    It's already moved. I am glad I moved it, it looks better and made me put some thought into making it a true functional CAI. It's airtight and draws from the factory hole through the passenger, it also gave me a place to mount my fuse/relay box, and a nice hidden channel to run wire loom through. I will post some pics of it tomorrow.
    My build
    Aug 2011
    Got the computer back and she runs great!!! I got a few questions though about it. What is the voltage output for a 2005'ish 5.3 setup. The guage in the cab is reading high, very high. Also, I have no Tach, is there a trick to getting it to work? I know I have it wired in, but is the PCM signal strong enough for the 94 tac?
    My build
    Oct 2013
    Jacksonville, AR
    Are you using the older truck one or did you do the 3 wire LS one? You add that resistor yet, I'm curious to seehow that turns out.
    Aug 2011
    I am using the factory 05' 2 wire sender for the PCM and the factory 94' 2 wire for the instrument cluster. I am going to pick up the resistor at radioshack in the morning and will post the results.
    My build
    Mar 2013
    yes the resistor is the fix. worked perfect for me. i tried driving without it hooked up and the tach did nothing. pulled over, tied the resistor in and bam, tach started working like it should. and its accurate too.
