Page 3 of 3 FirstFirst 1 2 3
Results 21 to 22 of 22
Thread: 243 or 317
  1. #21
    Jan 2012
    Anacoco, La
    No, the 4l80 flex plate Impacted the converter n the pump, the 4l60 flex plate pulled the converter out of the pump. Maybe urs had the newer crank set up idk
  2. #22
    Oct 2003
    Navarre, FL
    I know that you didn't mention the LS3 heads as an option, but they can be picked up for around the same amount as a set of 243's and will be better than both of the other options. But if you aren't wanting to use LS3 heads I would vote for 243's.
