Page 3 of 3 FirstFirst 1 2 3
Results 21 to 23 of 23
Thread: Pacesetter Longtubes
  1. #21
    Oct 2011
    San Antonio TX
    Ive been through 3 right rear 275/55/20 with 3.23 stock within 18900 miles with a 4.8.
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
  2. #22
    Sep 2010
    North East Ohio
    It almost feels if my throttle body isnt opening. I just added a high flow cat tonight (cold ad hell)due to local emission checks. I also picked up a vet servo which I will install when it's not snowing. My garage is to short so the truck doesn't fit. Everything I have installed has been outside in gravel after work. So it's dark/ cold and snowing when I'm working on it.
    2010 Silverado 4.8 Ext Cab 4x4
    Cam, Stall, 4.88's
  3. #23
    Arizona/Utah
    It is fairly normal to loose a little on the bottom end after an LT install. Like has been mentioned a stall and gears will make a big difference. Bang for your buck after a tune maybe the best mods out there.
