Page 3 of 5 FirstFirst 1 2 3 4 5 LastLast
Results 21 to 30 of 48
Thread: Small security measures
  1. #21
    I'm glad i live in a town of 4500 people where no one has the balls to touch my truck.
    Sep 2010
    I'm not telling y'all what I did because basically I am an asshole, but below is a pic of mine before I reinforced it with some steel!!!
    EDIT: Joking of course, if mine works I will be happy to help out with what I did!!!
    2007 RC Silverado aka ?
    1998 Trans AM aka Red Dragon
  3. #23
    Orono, ME
    No need to swap anything internally, it all just bolts up. No modifications required.
    One thing we did: the rod that goes from the handle to the door mechanism, flip it over to the right side of the handle lever.
    So, instead of inserting it into the outside of the lever, insert the rod into the inside out.
    Reason: the lever on the rear handle is a little longer and I wanted to get the rod closer to it's original position.
    Doing it this way, will offset it just a tad, not much, and bring it closer to the handle.
    Oh ya, pop that small white bushing the rod rides on, and push it on the lever from the inside.
    I just know from research that several people have had issues using the stock back handles when not swapping the internals. Not saying it won't work, but I'd rather have it work 100% of the time than 98% of the time. It literally takes 2 minutes to pop the clip out of each handle and swap the levers.
  4. #24
    Orono, ME
    Also, guys with NNBS trucks prior to 09' watch out for door lock actuators going out on you if you do this mod, that would seriously suck. It is unlikely both would go at at the same time, but you never know. I think I'd be more worried about the battery (in the truck) dying.
  5. #25
    Door lock actuators are super fails on 2007-2009 GMT900 trucks. I have several sets of black handles. They may be missing the LF but no one in this topic wants the LF. The lever length is very different front to rear.
  6. #26
    my post got deleted.............i swear to god.
  7. #27
    Sep 2010
    Repost!
  8. #28
    all i said was you guys need some vigilantes down there.
  9. #29
    Use your truck as bait. Park in a sketchy parking lot. Hide in the bushes with something that goes bang.
    Feb 2005
    San Antonio Tx
    Quote Originally Posted by SilverSleeper View Post
    Ray gives me suggestions all the time, I just can't post them here!
    he is good at that...
    02 Chevy EcSb Z71, 5.3, Helix Tb Spacer, AEM Brute Froce Intake, Msd 8.5 wires, NGKTR55 IX, B&M 25k Trans Cooler, Hypertech 160, Nelson Tune, Nelson Harness & Ls1 fans, Fully Built tranny, tb2600, 216/224 551/551 115LSA, yeller z06 springs, magnaflow, cut-out, hi-flow cats, etc...
