Results 1 to 10 of 21
Thread: Hi... I'm new here!
    Dec 2011
    London, Ontario, Canada
    Talking Hi... I'm new here!
    Hey, my name's Shane. I live in London, Ontario, Canada. No we don't live in igloos, and I'll try to keep the "eh's" to a minimum . I just bought a '92 Sierra with a blown engine, so I figured... I might as well start this build off right. So I picked up a 6.0l that was supposedly out of an 01 Escalade with 150,000km. I'm going to be needing a LOT of help with this build. I'm still trying to decide which transmission to get, it will most likely be an 80e because I'll be pulling a trailer with this truck. I'm a Licensed Tech, but mainly work on newer vehicles that don't require much more than brakes and oil changes, so any help and/or suggestions would be very much appreciated! Thanks in advance.
    Oct 2011
    San Antonio TX
    Welcome to the site. Get ready to learn alot lol
    Best ET 11.54@114 w 1.52 60ft
    Raceweight 4905 lbs.
    Sep 2010
    Welcome to the site!
    Dec 2004
    San Antonio, TX Area
    Welcome aboard, from Texas. Lots of good info here and quite a few swaps done already.
    "ALisSa1 Silverado"
    Scrimpin Ain't Easy
    ( . Y . )
    Another damned Canadian! Great!
    Welcome aboard. The 80e would be great for you. I wouldn't even think about a 60e.
    Apr 2011
    East Texas
    Welcome to the site
    Arizona/Utah
    Welcome, hopefully your a little better behaved than the other Canuck that hangs out around here.
    Dec 2011
    Thanks all... I still have to source a tranny and PCM, but the engine will come with the wiring harness. I read through the thread on how to swap the 60e for an 80e, looks simple enough. I can't wait to get started, but the wife says it has to wait until after the new year, so I won't be checking in too frequently until I get started. I'm going to take LOTS of pics and keep everyone updated. It has to be done by March.
    Dec 2008
    san antonio TX
    welcome!
    Dec 2011
    Ok guys... Been working on getting some parts for my swap. Like I said, I have the 6.0L, and I just picked up a 70e tranny with 100,000 mi. Was the transmission a bad choice? Also have the harness, PCM, fuel pump and some more misc. parts. For my swap, do I need the offset adapter plates? Also, if I run the stock ex. manifolds, could I use a y-pipe from a nbs? And... I'm assuming that my transfer case will bolt up, or am I wrong? I would also like some suggestions on which camshaft, and torque convertor to use. I'll be running either 4.11 or 3.73 gears, and I don't want to compromise fuel mileage too much. Thanks.
