Sounds like anything will help at the moment with your shocks being soooo short.
Fixed....... GET THE RIGHT SHOCKS FOR THE FRONT !!.. get them as long as possible of longer or TAKE THEM OFF .. i went from running 10.6-7 with 1.8X .60 foots to 1.60 flat pulling mine off just to see how much the front was hurting me ... after that i got the correct shocks and springs and able to make it work correctly.. WARNING its not good or advise to drive without shocks and yes it sucks to drive down track but i was fustrated and didnt care
I went and bought some cheapy replacements and they were just as long so I didnt replace them. Gunna go back and see if I can get something longer. I could have sworn the stockers I pulled off were longer now im second guessing myself.
What drop do you have on the truck?
T-RAV99 GMC | 5.3 | Skinny White Guy Tuned
dmj arms I believe Its an arm drop not a spindle spring drop.
4" arms ya its got hell of a rake now. May bump down to a smaller dang rear tire. Supposedly I do have stock length shocks.
Kurt is right. Too many people play with the rear suspension thinking that's where the problem is. Is the front isn't working then you'll be chasing your tail forever. You could try some shock extenders on your current shocks.
Also make sure the control arms can move freely up and down without binding the bushings. If they do bind up you can just loosen the bolts until they can be moved with slight resistance. Just make sure they're tightened fully for everyday driving. If you have a sway bar, disconnect it for the track.
