Page 3 of 7 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 64
Thread: Using 2wd and slicks in a 4x4?
  1. #21
    Quote Originally Posted by CHEVROLADE View Post
    put that sucker in 4hi and go!
    It kills the top end extremely bad. Its hard to explain, but you can FEEL it wanting to go, but not going like it should.
  2. #22
    if u did pull the front shaft..would it leak fluid?
  3. #23
    Hey, cant you lleave in 4hi then put it back in 2 after launch.
  4. #24
    Takes about 5 seconds. Do that while holding on to a 4x4 burnout and a nitrous button.
  5. #25
    Gotcha.
  6. #26
    Supposedly, pulling these three fuses eliminates Stabilitrac, Autotrac, and ABS.
    9 - Antilock Brakes System 2
    59 - Heavy Duty Antilock Brake System
    61 - Antilock Brake System
  7. #27
    Mar 2007
    why not pressing stability button dor 5 seconds and will turn off stablitrac and autotrac?????
    ABS will not engage while running.
    There is mechanically imposible to launch in 4hi and after launch disangage to 2hi.
    Yo can move the levee or push the button but if you dont release the accel it will not lose the pinions.
    You have to make good hp to make the truck pull at the end.
  8. #28
    Because it still doesn't fully disable the stabilitrac and traction control. If ABS errors happen, it can throw stabilitrac codes and go into limp mode.
  9. #29
    Spring, TX
    Get a 2wd, problem solved
    '02 Silvy: Z71 EC Step Side 5.3L Nelson tuned
    2013 GMC Acadia: SLT1 Carbon Black
    1976 Corvette Stingray: Trying to save it, progress is slow.
    ^Ricky's Sweet PS Skilz
    09/21/2010 02:31 <danger_ranger83> I'm not really worried about the looks...I want it to be fast and ugly...bc no one wants to get outrun by something ugly
  10. #30
    Pittsburgh, PA
    i wouldnt run 2 different size tires with the newer 4wd trucks
    i run in auto, this allows you to launch with 4 wheels then it becomes 2wd later on
    running two different sizes tires will screw the abs up and confuse the truck, not mentioned youll need to readjust the tables in the tune for the smaler tires or the 6l90 wont shift right!!!!
    2014 Xsport- 3.5 Eco boost
    412 Motorsports
