Originally Posted by
BLACKLIST
just took stuff apart. NO IDEA WTF the noise was coming from. The springs all look to be good unless its an inner spring that broke? The noise was DEF coming from the passenger side head and over 2000 rpm. The car the last pull i did on it going to third fealt very weak in comparison to its normal feel.
Drained the oil, cut the filter open. Oil clean, filter looked fine. The motor actually looks great inside AFAIK from just looking at it.
The push rods are all straight and look like new, the rockers all move freely and seem to be perfect. I took one of the rocker nuts off, and there were some metal debris on the threads and what looked like a small piece of metal stuck to them. I used my tactical flashlight and looked in to see if the spring was cracked anywhere and didnt see anything. I have no idea at this point. I even pulled off the drivers side valve cover and inspected around in there with the same results.
I guess i just need to pull the springs out regardless and check everything out. Either way, i am running a pretty big camshaft and most of my buddies are telling me the way i drive, replace the springs at 20k PERIOD. I am getting ready to do a blower, so i was going to swap the camshaft anyhow. But just the not knowing or seeing what failed is keeping me in suspense. I just didnt really want to start taking the springs out yet till ive got new ones to go in. I am a brokeass right now and use the top dead center valve on piston/crane spring tool replacement so i cant really pull it all apart till ive got something to throw back into it. At the same time, i dont know if i even want to put springs in the 243s again, parts of me think i just need afr heads (which i can afford in about 1 month)for the blower adventures and id rather put them towards that. Who knows. i just need a break. Watching the tow truck driver drag my car that sits like a desicron off the ground onto the trailer was enough for me today. I really need a beer.
Chevrolade, i saw you sent more money. Ill get that stuff ready to go brother, today has just been a rough one. Please be patient my bro-mie. Ill get you squared away. Was not expecting this fun time.
At least i can see all of the valves, lol... I guess it could be worse so far.. I had that stupid ASP wabbley underdrive pulley though, so maybe the timing chain is about done or something, who knows. I still really think an inner spring broke on these Manleys.
Either way the springs i have are Manley dual springs purchased from HPE since initially i had the megadeath cam.
you mention you pulled the nut off the rocker stud and it had metal on it, did you check the ID of the rocker to see if it wallard out? the outer spring will usually break before an inter spring. the inside diameter of the outer spring holds most the load.
id be trying to find out where those shavings came from. i take it you didnt try and start it after you had it towed cause of battery failure?
Simple: 408 on steroids!
single digits coming soon!
