ok i will...im headed down to the beach tom with a full bottle so ill try and get a few videos
2008 GMC Sierra SLE....370ci LY6 with some goodiesSOLD
1995 C2500- LS1 swap with a mp112
build thread- http://www.ls1truck.com/forums/lsx-t...-ls1-swap.html
I would take the next 2 or so hrs and google the out of nitrous, plugs, afr, timing and all that crap. From what I've read a non projected tip plug like a br6ef (one step colder) is ideal.
This thread is awesome and has a couple good links also.
http://www.ls1tech.com/forums/nitrou...o-read-me.html
Good call. Be safe man. And keep an eye on them.
im running the br7ef's in mine, two steps colder and non-projected. Running full timing on the 100 shot and i have a IAT timing tricker wired up to pull 4 degrees of timing when i run the 150 shot. I cut a 1.64 60' spraying outta the hole with a 3600 stall and bone stock 5.3. And that push button switch is a bad idea my friend, ive seen a couple nitrous backfires because of it. Play it safe for now, but i would save up for a harris speed works microedge.
basically this
http://www.ls1tech.com/forums/nitrou...icker-mod.html
and while i was at it i also did this
http://www.performancetrucks.net/for...iat+relocation
Im like you.. I know very little about the stuff but eager to try and learn.. Simple HP..
