The A/C accumulator is located on the firewall passenger side of the engine compartment. It is the aluminum tank you will see with the AC hose coming from it. The low pressure switch is screwed on to a fiting on the side of the accumulator and has two wires on it. One should be hot when you turn on the A/C on the dash, the other is controled by the pressure it sees and sends a signal to the PCM.
