Cam question...again!
So I have been deciding on a cam to throw into my 5.3l block, and along the way contacted Comp Cams listing the mods going into my 88 GMC Sierra. They forwarded me a cam profile stating that it would yield good gains... thought I would share it with you guys and see what anyone thinks, pros-cons? Is this a streetable cam or is it too mild? Looking to make a fun truck out of it, not necessarily for the strip, but laying some nice burn marks on the ground would be nice!
List and things to come are 3in exhaust, ls1 or ls6 intake, no head work till much later down the road.. planning on keeping it N/A... gearing and stall I am a little unsure about at this point in time but someone's opinion would be helpful since this is my first conversion! Thanks Gang!
Comp Cams 54-450-11
XFI Xtreme Truck Hydraulic Roller Camshaft
# GM LS/Gen III Engines Lift: .513''/.520''
# Duration @ .050'': 206°/212°
# RPM Range: 800-5000
http://www.compcams.com/Cam_Specs/Ca...csid=1095&sb=2
Reason: *little easier with the cam specs*
- You may not post replies
- You may not edit your posts
