no prob, have fun with it.. The most expensive part, since you said dubs, instead of 18's, is, you might be forced to relocate shit on the inner fenders.. and the ecu wires need to be lengthened and the s10 has 98 wires, i'm sure the fullsize is around the same.. so that will cost a little bit extra.
But good luck and just ALWAYS carry extra air line and fittings in your truck, never know when you might spring a leak. Being in hot climate, leaks will happen. Mike Finnegin from MiniTruckin, blew his line apart in Texas, b/c of the heat.
91 s10 - bagged and bodydropped...getting rebuilt
91 nissan - backhalfed and bagged
