Page 3 of 6 FirstFirst 1 2 3 4 5 ... LastLast
Results 21 to 30 of 60
Thread: Buyer's Remorse
  1. #21
    Oct 2009
    painesville, ohio
    Silly idea....I see everyone is saying mods, etc. But what about the possibilty of a weak fuel pump?? That would for sure make something run like poop. Wouldnt hurt to get the psi checked while it is driven.
    2000 Silverado 2500 4x4
    6.0 V8
    Nelson Tuned
    True duals w/flowmaster mufflers
    cold air intake
  2. #22
    Nov 2009
    Appleton,WI
    dropped some serious coin this weekend
    Extang tonneau
    Banks exhaust
    Eclipse cd player
    install kit/harness
    RCA cables
    Image Dynamics CSX62 v.2 door speakers
    Vararam CAI
    sub box from subthump
    LPP long tube headers and ORY
    SLP underdrive pulley What overdrive alt pulley do I need? what belt?
    SLP shifter handle
    E3 plugs
    MSD wires
    ARP header studs
    Cometic MLS header gaskets
    Don't know about the gear swap right now, gonna cost about $1,000 just for parts...
    might change tire size on the stock 17's if I can find someone to buy the 265/70R17's on there now. At least then I could do a 4/6 drop on it.
    Still need a few odds -n- ends for round one mods.
    Wire for amps
    3" SS band clamps
    sound damping materials
  3. #23
    Quote Originally Posted by Slow Ride View Post
    Extang tonneau
    Banks exhaust
    Eclipse cd player
    install kit/harness
    RCA cables
    Vararam CAI
    SLP shifter handle
    E3 plugs
    MSD wires
    ARP header studs
    Wire for amps
    3" SS band clamps
    E3 plugs
    MSD wires
    Those are a waste.
    And how the hell is it going to cost $1k in parts for a gear swap? If its a 2wd you can get a set of gears for under $300. Even a 4x4 would be under $600. You must not be shopping in the right places.
  4. #24
    Nov 2009
    Appleton,WI
    Gears $160
    seals and bearings $100
    Elocker $700
  5. #25
    Gears $160
    Elocker $700
    E-locker is also pretty worthless.
  6. #26
    Augusta, Ks
    Just go to rons machine and get you 4.10s and a tru trac. Its only 600 for all that and install kit.
    2004 Buell XB12s
  7. #27
    Augusta, Ks
    The header gasket and bolts were a waste as well. Just use the gaskets and bolts that come with the headers.
    2004 Buell XB12s
  8. #28
    Yeah... There's nothing wrong with copper or the felpro gaskets.
  9. #29
    Nov 2009
    Appleton,WI
    The only thing I'm worried about with a tru-trac or locker is in winter. I don't want to be sideways at every overpass. I'm investigating if the tru-trac diffs stay unlocked at highway speeds when this happens. I don't want an exploding gov-lock. I've read the tru-tracs have some reliability issues in stick shift cars, but that might just be with slicks and big HP. Standard detroit lockers are kind of finicky at gear changes in a manual transmission vehicle, they tend to get really squirrelly when they unlock and then relock.
    As far as the bolts. I didn't want to mess around with bolts this time. I'll try studs. Plus S/S is shiny.
  10. #30
    Fort Worth, Texas
    Gears $160
    Elocker $700
    Why would you want a $700 dollar E-Locker in a 10 bolt, go with the Tru Track and don't look back.
    E3 plugs
    MSD wires
    Those are a waste.
    What's wrong with the E3 Plugs, just wondering cause I've heard good things about them. They were tested on Spike's Horse Power TV, they made more horse power, better gas mileage, and lowered emissions.
    As far as the gears I'd agree with you though. I have Yukons front and rear, front and rear master install kits, and Tru Track all from Ron's and all that shipped to my door was under $1000....
    2002 Silverado 2500HD LB7 CCSB LT
    EFI Live by Rob at ATP, Edge CTS Insight DSP 5 control, S&B CAI, PPE boost valve, Pro Fab AIH, AirDog II 165, PPE WIF sensor delete plug, 5" stainless exhaust, Cognito braces & HD tie rods, H2's 315/70 R17 BFG's
    2004 Tahoe LT
    2006 Silverado Z71 LS
    1971 Chevy C10
