Page 3 of 3 FirstFirst 1 2 3
Results 21 to 29 of 29
Thread: busted rearend mod!!
  1. #21
    what gears did you have in before? I have some 3.42s with 100 miles on them that ill let go for cheap
    verona, virgina
    Ive got 3.73s and they are still in good shape thank god! I found a complete used rear for a direct swap if needed for 675
    03 yukon xl:intake, longtubes ory,performabuilt lvl2,circle D 278,tune, tint, lt1 fans
    92 z28: lb9 air foil vette servo magnaflow catback adjustable pan hard rod Lcas lcarbs
    86 trans am: lm7 hot cam th350 3500 stall
  3. #23
    That's too much for a stock swap and if you are correct that the pinion bearings and the gear set is OK, it will be very simple for the layman to swap stock diffs. There are no adjustments as long as you use the side bearing shims on the proper side they came out of the housing you are still using and the caps get torqued. It's not the book way, but it is the 98% way.
  4. #24
    Maui, HI
    Totally agree with the above ^
    Had to deal with my spider gears going out and the local shop wanted to try quoting me $1200 cause their thieves out here... I marked the ring and pinion location along with mic the shims for reference n kept them on their respective side. No problems or whine luckily for over 40k miles now.
    OH btw... nice bust ya got there
    99 Silverado 1500 4x4 RC 4.8
    4L60E, 3.73, Homemade CAI, 92oct Quik tuned,
    08 Tahoe radiator/fans, Dumped exhaust... summed up one loud pig caller |[226K! on odometer|
  5. #25
    verona, virgina
    yeah i been looking for a replacement unit and found a few in the $100 range.got a guy im gona call tomarrow about putting it in or i may just do it myself.
  6. #26
    verona, virgina
    I went and got my carrierr bearings today! friend of mine at the store gave them to me for his cost! Im debating on spending the money on a true track. Found a company on ebay selling them shipped for $405 my question is would i still be ok by just putting it back in with the old shims like they were or if going to a aftermarket diff throw it off that much?
  7. #27
    Quote Originally Posted by screamin86 View Post
    If you replace g80 with g80 you are going to have to replace it again unless you drive like granpa Moses. Wasted money in my opinion.
    you will need it set up correctly. Get some one to help you with that. I hear Nathan/GasGuzzler works cheap and does good work.
  8. #28
    Maui, HI
    Quote Originally Posted by zeake View Post
    you will need it set up correctly. Get some one to help you with that. I hear Nathan/GasGuzzler works very affordable and does good work.
    Cheap and good work just dont sound right together, especially on the installers half.
  9. #29
    verona, virgina
    Well since im in virginia i doubt i could get him to set it up for me! Lol
