Results 21 to 30 of 32
Thread: Nelson Tune for Stock 5.3
  1. #21
    Sep 2009
    I am by no way saying that GM's PCM's are going to be the most efficient and put out the most power. I'm just saying that they will optimize for the higher octane but not fully.
    2000 GMC Sierra 5.3L 4x4 ECSB
  2. #22
    newburgh, NY
    Quote Originally Posted by fastlt1 View Post
    Why can't they tune WOT for 93 octane and part throttle and cruise for 87 economy?
    You can, but once you go to WOT with a tank full of 87 on a 93 WOT tune you will have nothing but knock. so to make that work you would have to have two separate tanks one for cruise and one for WOT. So it makes no sense at all to do it.
    Step 1. crus at it.
    Step 2. get a hammer.
    Step 3. torch it.
  3. #23
    Sep 2009
    Quote Originally Posted by Melissa@NelsonPerformance View Post
    once you submit your form, usually takes 1-3 days before it ships..
    Is a PCM shipped to me? Do I return mine as a core? Would this require a crank relearn?
  4. #24
    SA, Texas
    We provide a PCM first, then you will have 20 days to return the core back to us.
    Crank relearn can be performed with a tech II or tuning software, its takes about 5 mins to perform.
    Her name is A Meli-
    "If everything is under control, you are going too slow."- MA
  5. #25
    Sep 2009
    I don't have access to either, so I guess a tune isn't an option for me. Sorry!
  6. #26
    Augusta, Ks
    Tune is always and option. I didnt have to do a crank relearn
    2004 Buell XB12s
  7. #27
    Sep 2006
    THE 405
    The local parts store should a tech2 to rent you
    midweststreetcars.com
  8. #28
    Nov 2009
    Indy
    I had the crank re-learn done at the local stealership for free, at most they will charge you a small fee. They plug in there tech2 and rev the engine a few times and its over!!! Get the Nelson 93 tune, you will make up the difference of price per gallon with better mpg. It will take a few heat cycles for the pcm to learn, but when it does, Hold on!!!
    2004 GMC Seirra 1500: 3" Body lift, 295/75 Nitto Terra Grapler's on Stone Crushers, cam keys, Bilstein 5100, 5.3 liter, K&N 77, Stainless longtubes, Banks Monster Exhaust, Nelson Performance 93 tune, 2600 stall, Ls1 fans, Taylor wires, NGK tr55's, TransGo shift kit, Corvette servo, TCI pan, 4.10 G80 w/ TA Performance, Optima
  9. #29
    Quote Originally Posted by Toadz View Post
    I didn't do a crank relearn when I got my Nelson PCM.
    Quote Originally Posted by sleeper1500 View Post
    +1
