nice build, i like how you did the factory fuse block and pcm placement...u could make a cover for the fuse box and i would look factory![]()
I have an '86 454 suburban where I want to do the same thing. I also have a stock th400 trans. I have questions about your mount adapter plates.
For the plates you used, did you use the original 454 engine & frame mounts? Also, I want to verify that you didn't have to relocate your TH400 at all? That would be nice, since no driveshaft changes would be necessary.
so, it looks like all I would have to do would be use 1" setback mounts and the engine will drop right in w/o relocating my trans?
these are the plates I was thinking making & using. are these the same as what you used?
http://matt.undiagnosed.org/ls1/imag...ount_plate.jpg
carshopinc mounts, are these what you used? they look like they are in fact further back than tthe above templates.
http://www.carshopinc.com/images/Picture042.jpg
thanks for posting the original thread!
Morgan
nice i want to hire you lol its good to know a guy that can get a job done simply
1996 - BIG BLACK: 5.0 | cognito 10+3 | 22/37 toyo | 14B/4:56 w discs | built 4l60e | corbeau
1999 - OBS SS RICER: 6.0 lq4 | autometer | jdm! | whipple | FLT billet 4l65 | yank | truetrac
1954 - OLD RED: Chevy 210 - 3 speed | 235 inline 6
