ouch
ouch
it was the ignition switch... 140 for part and labor. Been fixed for a month now.
Program is back on and she grabbed 2nd for the first time.![]()
04 Silverado Z-71 Extended Cab
Magnaflow, 10.4 TV 50 wires, tr-55ix, Synthetics, HID's, JL audio, 33.5", leveling kit, tuned, CAI, vette servo, cam, valve job, pacesetter. 9.3@77.5 and 14.5@93.4
06 2wd
custom cam, tune, 3.73's, servo, HID's, 10.4mm wires, long-tubes, CAI, magnaflow, 2.5" shackles, Circle-D 3200, UD, JL Audio 4.1, Alpine 5ch
Are you really sure the ignition switch fixed it? Wow. Thanks for the update.
No problem. Was a surprise to me to. They knew exactly what it was when i took it up there. Must happen often
06 2wd
Yes, it happens often at the dealer level. This and the knowledge of the difference between electrical trans codes and mechanical/hydraulic trans codes helps too. Also having access to all of the schematics and bulletins helps.![]()
