I am looking for all the wireing to hook up my rear view mirror with temp guage. My 99 sierra didn't have one, and I would like the factory stuff.
I am also looking for the center seat with the fold down consol with the cup holdes on the floor.
1999 GMC Sierra SLE sc sb 4.8l 4L60E, Comp 1.75 roller rockers, graniaelli maf, garneaelli wires, Aem brute force intake, BBK 80mm tb, Nelson tune, 2/4 drop, Denali rims, custom grill, Denalli guages, Edelbrock IAS shocks, Tahoe E-fans, Nelson harness, and tune, McGaughy's 2" drop spindles, New matched coil springs, Air Lift rear lowerd air bag kit, Air Lift wireless remote
List of things to do
4.10 gears and a new posi, Lt headers, Cam, Heads, Intake,
--'01 SCSB 2006 Full RST Conversion, Built 6.0L HO & 4L80E, **Always Under Construction**
--'07 BMW 335i Coupe Dinan 3.0L Twin Turbo (My DD)
Black On Black
Built Not Bought
I've done this swap before. You need the newer style mirror with compass and temp, the temp sensor, and a custom wiring harness (I made mine). You can reuse the plug it has now but you have to add two wires for the temp sensor and run them to the front of the truck to the stock sensor location. The power and ground for the lights also powers and grounds the internal compass and the brain. The plug in is the same on both mirrors. I did this on a 99 I added an 01 compass temp mirror to. The factory wiring on the newer ones is part of the headliner harness which is too much of a pain to swap just to get two more wires.
I may even have a mirror. I'll look in my stash.
Thanks I have the mirror out of an 01 in there now. I just need the sensor and wireing. I am not to keen on wireing could you send me a drawing on how this is done????
Add a wire to #6 and #7 on the mirror plug. Run them to the front of the truck. Get the sensor and pigtail from the dealer or a junk yard. Connect the pigtail to the two wires you ran and plug it in. Done.
BTW, my mirror is compass only. I even hot wired it to see if it works.
bump
Black On Black
Built Not Bought
do you have the triangle peices that snap in on the doors near the bottom of the window?
Passengers side window motor and passengers side armrest piece where the window/lock buttons are?
On my truck, I bought a set of complete, full-power doors off craigslist and swapped the guts of them into mine. My doors were manual windows with power lock on the drivers side only. Ill have to check on the armrest, but I believe it is moulded to the door panel itself on the non-power door panels that I have.
Black On Black
Built Not Bought
