I bet if you knew how to weld, it wouldnt fail... You need to weld like this ------------------->
I bet these would never fail,
jk
jk
The best TIG welds on light duty parts use NO filler. When you TIG thick material obviously you need filler rod but only because of the much greater heat it needs. You can TIG small parts fully all day long and never pick up a rod. I'm with Greg, FILL HER FILLER with MIG.
Mig breaks we seen it before.
And again if you mist it. WE use filler rod while welding.
Online Store
[/CENTER]
Hey I gotcha. No harm intended, no insult or malfeasance given. Reread it![]()
