Page 3 of 3 FirstFirst 1 2 3
Results 21 to 28 of 28
Thread: Yes...another one!
    Oct 2005
    drinking your alcohol
    But still...you have a RCSB. You have a lot less weight than me. That takes out the stall and TB. Ok, so I have gears over ya...and your slightly bigger cam makes up for that. So, when it comes down to it, we are evenly matched. And I have no power adders--unlike your cheatin ass...
    im not that much less weight with all the crap i have piled in it at all times....
    and my cam will KILL me out of the hole and your gears will help you... i could probably Flinstone this dang thing outta the hole better than it moves out
    and besides you always talk about how "slow" my truck is... if its so "slow" why are you scared of a measley 100 shot... i cant even spray out of the hole anyways so youll still be out ahead
    cmon tyler.... dont be scared....
    if i lose ill buy you some rogaine
    DamnYankee: my nana failed
    Yep, that one second 8th mile difference is probably the result of just a 100 shot.
    Wait, ummm...I'm confused.
    HAHA...fine bitch. Lets run em this weekend. I know I will lose on the spray. I rode in your truck when you sprayed against that one guy's M5--and you stayed nose to nose with him...
    Oct 2005
    im booked starting saturday morning.... unless your coming to the dyno day ill have some free time to hurt your feelings
    Oh, I will be there. I am leaving late Saturday evening to head to the NOLA for a friend's bachelor party, so we are going to need to get our running in before then...
    May 2005
    that's sick...and you're an xtra cab as well!!
    ●01 silverado x-cab w/5.3 ● STS GT-67 ball bearing turbo kit(relocated under cab)● Comp 918's ● Comp Hardened Pushrods ● Comp Cam 212/216 .557/.561 114 lsa● 42lb injectors●Walbro 255lph inline●OBX Intercooler● YANK 2600● Nelson SD Tune● Magnecore 8.5mm wires● STS meth Injection●Comp valvesprings● 05' e-fans w/ 34" radiator● ARP rod bolts and headbolts● NGK TR6 plugs● Eaton Posi● DB Rods bagged 4 link● FLT lvl5 4l65e● Apexi AVC-R boost controller ● z06 6 piston brakes front/4 piston rear 14" rotors ● Goodrich SS brake lines● powdercoated frame
    Oct 2005
    so you wanna take away the 1 thing that i have that puts us on an even playing field.... yeah... thats fair
