I'm buttoning up the last bits on my swap and I can't get the cruise to work...I have an 04 avalanche 5.3 and swapped it in a 93 obs..I used the existing wires that came in the plug from the obs cruise box. I used a relay with the 12v positive signal coming from the brake engaged switch and the other to ground. The wires I'm connecting with the relay is the on switch from the obs plug. I also hooked up the blue and green set and resume switches to the new harness. I can hear the relay working when I hit the brake, but I can't get a set signal to go through...any ideas is appreciated.
