Had the O2 codes since the install, really haven't driven it much. So those could be in the wiring I guess, the harness came with the eng. As for the knock sensor I did have a coolant leak but fixed it as soon as I found it so I need to pull the intake and check it out. I think there is a thread for checking it on here. Don't think that I have any vacuum leaks but will double check for that also. So running lean can cause those codes as well?
'86 Silvy- '06 6.0/4L80E, K&N, 2.5 X-pipe Magnaflows, 20" Foose Wheels, Auburn Pro, 3.90 Richmond Gears, and the list is growing!!!
