Page 3 of 3 FirstFirst 1 2 3
Results 21 to 29 of 29
Thread: This Truck is incredible!
  1. #21
    Quote Originally Posted by Jamest View Post
    I can't wait either. The one thing I like on this truck is the normal drivability. Allen did an awesome job of tuning this bad boy. Some of the guys at the Chevrolet house couldn't believe the way the truck runs. The were in awe of Allen's handy work. They said it sounded stock until I got on it and then they wanted to see what was under the hood!
    Jamest
    You make me wish I was close to Texas. If I had enough employees I''d haul my truck down there to get tuned. As it is it won't make it. It dies when it gets warm and you goose it a little then then hit the brakes it dies. The afr gauge goes really lean at idle and it shakes as if it has a large cam in it. I am so frustrated with it. Until I hit the gas doing 30 and it starts getting sideways. I lost traction in 4wd in the rain for the first time today. That was kinda kool.
  2. #22
    Zeake--do you not have tuning software? I thought you did? Since you have a 99, can't you just turn up your throttle adjustment screw on the TB to keep the idle slightly higher to keep it from dying on you?
  3. #23
    I have the software, but not the time to learn to use it. I thinks its best I leave it to the professional. Its more than just the idle screw. It goes lean idling and just runs like poop. I sent Allen some logs and am just waiting on the retune.
    I would love to take it to Texas but the fuel alone would run about 700.00 to haul it on a trailer there and back.
  4. #24
    I hear ya on not having time to learn something new. But damnit--if I had the software just sitting on the shelf, I would move it into the pooper room so that I could read a little here and there while playing UPS man...
    But yeah, if you are sending Allen scans--he should be able to correct them and send you new tables to make it run correctly...
  5. #25
    Jan 2006
    I am going to try and take some this weekend. I post then up.
    Jamest
    Pictures!!!
    12 Sec. Club! SOLD
    SOLD***
  6. #26
    Jun 2007
    awesome i wanna see this machine run .hey ,could you post some idle video ,i am debating on a turbo setup but id really like too hear how much they wistle at idle .or when does it start wistling ,i just dont know if i can listen to it all the time.does it wistle at normal driving ?or just getiing into boost hard.id appreciate it i really am wanting one.
  7. #27
    Quote Originally Posted by Ramsey View Post
    Mine doesnt whistle at all during idle because its in such low vacuum mode and I dont even have exhaust. I know james has the front mount which is different, but I heard that theres are a lot quieter than mine anyway
    awesome i wanna see this machine run .hey ,could you post some idle video ,i am debating on a turbo setup but id really like too hear how much they whistle at idle .or when does it start whistling ,i just dont know if i can listen to it all the time.does it whistle at normal driving ?or just getting into boost hard.id appreciate it i really am wanting one.
    I'll post a video as soon as mine gets drivable. The whistle is not constant but the blow off valve is loud and its great to let off the gas next to a ricer.
    The juice is worth the squeze on turbo. I love mine. Just wish I could get a live tune. I think it would help me tremendously.
  9. #29
    Jan 2006
    I will soon.
    The turbo is very quiet. You can hear it well when the cutout is open, but full exhaust is very quite under normal driving conditions.
    Jamest
    12 Sec. Club! SOLD
    SOLD***
