Page 3 of 3 FirstFirst 1 2 3
Results 21 to 30 of 30
Thread: hey guys tranny ?
    C10, when I was talking about the bands and whatnot, I was implying them slipping when being released for the 3rd gear shift change...but yes, you are right in the mechanical operation.
    Ramsey, you can go ahead and do the 46-MOD only if you want to. To drain almmost all fluids out, you definitely need to drop the pan and valve body, second accumulator, etc. The converter holds quite a bit of fluid...I'd say somewhere in the neighborhood of 3-4 quarts. To completely get all fluids out, you need to take the tranny and converter off. I know its a painstaking process...
    Jun 2007
    so you reallly think the fluid could be a contributing facto ,ha.boy something new everyday.lol.i guess tomm thatlll be my project.and go from theyre.
    Yes, it very well could be. Since it is brand new and all, drive it for a bit and put some miles on it. See if the problem goes away once all of the internal parts "find their set." Let us know how things turn out.
    Oct 2005
    Baton Rouge, LA
    I bought an aftermarket deep pan for ~2 qts addition to storage. Drain plugs are the best. Just make sure you put additional gasket sealer on the plug. Have yet to have a drop fall on the concrete since.
    TX (or anyone else)... is there any issue with blending small amounts of fluid? Reason I'm asking is b/c I know how much of a pain it'd be to r&r a trans, and maybe a 2 - 4 quart fluid capacity within the converter (depending on size of TC) would be marginal compared to the amount being installed in the trans. Thinking he could blend, run, drain, blend again, run, drain, and fill again, run to see if there's an improvement. LOL
    Yeah, I thought about the fact that he could drain -- fill, drain -- fill, etc like you said until he gets it right, but that is a pain in the ass. It might just be easier to do it all at once versus effing with it several times...
    Oct 2005
    Baton Rouge, LA
    unless you have a pan with a drain plug.... easy! lol
    Mar 2004
    NY
    Well Ramsey better get it fixed quick because LVD is open on wednesday nights now.
    2015 GMC Sierra RCSB Z71 5.3
    Jun 2007
    Quote Originally Posted by FLATOP08 View Post
    ya i know i cant wait too take it theyre and blow it the hell up.im pissed i just got it going again and im having all kinds of **** go wrong.i will be going to the track tho .do u plan on going down ?if so let me know sometime ill meet you therye.
    Oct 2005
    Baton Rouge, LA
    Found that my problem was pressure related. Changed the modifier on the 4-3 downshift tables, and the "slippage" b/t the downshifting has nearly ceased. Have to look at a few other things before testing once again.
