Results 21 to 30 of 33
Thread: Thinking of going all black?
  1. #21
    Feb 2008
    Alabama
    Its the ratrod look
  2. #22
    Quote Originally Posted by SCIV View Post
    Do it! But you will have to get new rims, or get them coated, and pull all the chrome too to complete the look.
    Then flame the front!
    flames ? hahhahah
  3. #23
    May 2006
    Waco TX
    The only thing about flat black is that you can't sand and buff it. And when any paint gets sprayed, there will be some dirt that gets into the paint and they might even get a run depending if they can spray worth a ****. If you spayed a regular gloss all the dirt and runs get sanded and buffed out. But since you spray it flat its gotta stay. Thats something to think about.
    The way I would spray it so that it would stand up to the wheather is spray the black base and then put a flattening agent in the clear coat and it will go on shinny but dry flat. That way it will still last for YEARS in the wheather!
    GO FOR IT! I LIKE THE IDEA!
  4. #24
    Quote Originally Posted by Red03SilSS View Post
    thats how its done it costs just the same as a regular paint job because all the same materials are used, you can get it done for about half if you just do black primer instead of base with the flattner. I think ill do the primer if it turns out nice ill keep it but if it looks ****ty they can just go ahead and paint it.
  5. #25
    Black primer will fade to grey in the sun.
  6. #26
    the car has to be primered so just do it in black if you like that style you can have them paint it flat black or if you dont like it paint it gloss, the black primer is only temporary, both shops i went to said the primer would last for quite a while but eventually would start fading. and if it fades to an off grey it would still look sick primered trucks just look mean to me.
  7. #27
    May 2006
    Waco TX
    Quote Originally Posted by lamborado View Post
    almost all base that is sprayed has flattening agent in it. To creat the flat effect the flattent has the be in the clear as well so that it does dry glossy. I would not recomment black primmer like you said up there. It wont stand up to the invroments. Now I do have a single stage flat black that would work and be alot cheaper, but im not a fan of single stage paints.
  8. #28
    you guys arent pickin up what im puttin down apparently let me break it down retard style. instead of grey primer do black primer if it looks good paint the vehicle flat black, if it doesnt look good paint it gloss black, use the primer just to get an idea of what it will look like. dont give a crap how long its gonna stand up to the environment its just to look at and decide max time out in the elements an hour.
  9. #29
    May 2006
    Waco TX
    I see what your saying. Retart stlye helped me out alot!
  10. #30
