Results 11 to 20 of 21
Thread: no 13 s for me
  1. #11
    Aug 2005
    Houston,Texas
    scoggins dickey or gmpartsdepot.com
    99 ECSB 5.3 LS6 CAM AND SOME BOLT-ONS BEST TIME 13.6@97MPH
    http://i104.photobucket.com/albums/m...wTRUCKS008.jpg
  2. #12
    Jan 2007
    would you recommend this cam for my truck 5.3 4x4, what did you upgrade with this cam
    thanx
    -jax
    2001 silverado 4x4 ext. cab, 2006 front end, cold air intake, msd spark wires, flow master, hp tuning, 20" bbs rims, 2" drop in back, e-fans
    http://i134.photobucket.com/albums/q.../jaxbigger.jpg
  3. #13
    Sep 2004
    Breaux Bridge, LA
    great times adrenaline
    some 26" tall et streets would help that et and give you more gearing.
    jaxpewter, since your truck is 4x4 and heavier, i'd recommend the 01 z06 cam over that one. it has less duration and less lift thought but it will be better to get you out the hole.
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    10.35@130 pump gas LQ4
    Knothead Racing
  4. #14
    Jan 2007
    jaxpewter, that z06 cam would be a good upgrade of cam for you but if your going to waste money on new springs since its not a direct replacement, u might as well get a little cam 212/218. now if u want to upgrade your cam to a better direct fit one go for the LS1cam where u dont have to change anything and u can find it for about 50bux. if i had ur truck i'd get full bolt ons and a little cam with a nice 3inch exhaust so it can sound mean when its tearing up the mood.
    12.82@103.82mph w/1.78 60ft
    TUNED BY DAN
  5. #15
    Jan 2007
    thanx for the advise guys, how much difference would the ls1 cam make? can you recomend some bolt ons
    and the spesific cam i should get, my goal is to get 13's but i know my truck is to heavy and a daily driver
    so any recommendation would help alot just to move alittle faster and maybe give compition to the cars my
    friends Z28 beats (love the sound of a 01 z06 cam but if something else works just as good with out changing springs,rods,and rockers, i rather do that) thanx
    -Jax
  6. #16
    Jan 2007
    jaxpewter, well since you actually want to give some z28s a good scare with a good strong cam a 212/218 would do the job just perfect since that cam doesnt require a stall. to compliment that cam go with full bolt ons being e-fans, K&Nintake, LT headers, pulley, spacer, exhasut w/3inch Ypipe and when ever ur down at the valley get yourself a good DanTheMan tune. He tuned my friends ext.cab Z71 and he's giving singlecab 5.3s good scares and thats cus all he has is a tune and exhaust and still has his hitch, extra tire, and heavyass toolbox with tools inside.
    TUNED BY DAN
  7. #17
    Jan 2007
    thanx alot i'll go look that up right now As far as those bolt ons i have my e-fans wired up just need to actually put the fans on, and i have fram boost cold air intake, i'll get LT headers, pulley, spacer, exhasut w/3inch Ypipe, and i have hp tuning do you think the tuning you said will be better thanx
    -jax
  8. #18
    Jan 2007
    <div class='quotetop'>QUOTE(jaxpewter2016 &#064; Jan 19 2007, 12&#58;52 AM) [snapback]80320[/snapback]</div>
    thanx alot i&#39;ll go look that up right now As far as those bolt ons i have my e-fans wired up just need to actually put the fans on, and i have fram boost cold air intake, i&#39;ll get LT headers, pulley, spacer, exhasut w/3inch Ypipe, and i have hp tuning do you think the tuning you said will be better thanx
    -jax
    well Dan is easily one of the best tuners in the nation, he&#39;s right up there with Allen Nelson. His work speaks for itself...who are u tuned by?
    TUNED BY DAN
  9. #19
    Jan 2007
    Comp Cams GEN III/LS1/LS6 350 Xtreme RPM Cam 212/218. Nice upgrade from stock, good torque, good daily driver cam. Very string midrange cam. 1200-6000 RPM.
    Lift: .522/.529 Dur@.050: 212/218 LSA: 114
    is this the cam u told me about
    gold 87,s brother does my tuning hes from roma i think you said he was on rgv truck site, when he did my tuning i felt alot of difference (yesterday on the way to the valley i floored it and it hit 85 on the speedomiter and it didn&#39;t want to shift it was on 5500 rpms just spinning for a while until it finally caught and dropped back to 75 mph but the streets were all wet it was fun either way and even better seeing a state trooper a couple of miles down the road pulling over some other car lol.
  10. #20
    Jan 2007
    <div class='quotetop'>QUOTE(jaxpewter2016 &#064; Jan 20 2007, 04&#58;07 PM) [snapback]80558[/snapback]</div>
    yeah man thats the one. its a really good daily driver cam with a good high end. that should do the job in your truck really badass especially wen you get full bolt-ons....oh laverito tuned your truck then. the only truck i know tuned by him is that g-old truck and its running great. i&#39;ve heard really good things about that guys tunes especially for the experience he has. but i mean if you have the chance to get it tuned by dan i rather go to him but is all up to you.
    TUNED BY DAN
