Ok guys, this is it! I hope this was worth the wait.
Front Mount Turbo System
Here is a new turbo kit from Trick Performance. Currently, Nelson Performance is the only distributor for this kit.
As you can see, the kit is built completely from stainless steel and includes all the turbo parts needed to get running.
Parts:
T62 turbonetics turbo
all hot parts
all inductions parts
boost smart blow off valve
wastegate
air filter
everything shown in the pictures
This kit has a lot of potential! An intercooler kit will be available very soon.
As you can see this setup doesn't have an intercooler, however, after measuring intake temps, it's lower than most non-intercooled supercharger kits.
The base kit is setup for 6psi.
Boost will come in as low as 2400rpms.
The downpipe ends about where a long tube header would, then it's up to the customer to finish it out. A small section of exhaust is all that is needed to connect to your stock or after market catback.
Spark plugs are still accessible.
Flex/mesh tubing prevent cracking
Base kit comes with a 3" downpipe, upgradeable in the future
Driver side exhaust manifold remains and the passenger side is replaced with a header.
Optional: The air filter actually sits below the stock air filter plate.
Air filter location: Air filter location The air filter has 4" intake tubing.
Here's a pic of the header and downpipe installed, the inner fender was cut away for viewing:
Downpipe
This kit can be upgraded to a twin turbo system in the future!
The base kit will start at about $4050.
Let me know what you think guys!!!
allen
