very good progress, your miles ahead of me. Keep on her![]()
'82 C-10......project truck.....
ridnlow..in the first picture, that is the pump that you put into the tank right? and then do you also have an external fuel pump? thanks
Project: 91' short wide:GMC front end update with billet grille and all clears, 17x8 & 17x11 Torq Thrust II's5/7 drop, almost totally shaved and 93 Deville tailsFuture Plans: 2001 LQ4 6.0L & a T-56
DD: 98' 5 speed GT : Dumped Exhaust, CAI
<div class='quotetop'>QUOTE(c1500 @ Oct 12 2006, 12:01 AM) [snapback]68987[/snapback]</div>ridnlow..in the first picture, that is the pump that you put into the tank right? and then do you also have an external fuel pump? thanks
yea that is the one we put in the tank.. No i do not have an external one.. The motor will stay stock for quite some time.. so I hope the in tank should be suffice..
Looking for a 05-07 Ext Cab or Crew Cab Chevy or GMC with some mods.. PM if you have anything
Sweet! I have the same leveling beam for setting motors. Does the paint peal off of yours from the lower wheel when you tilt the motor back? If so make sure you have all of the holes covered. Good luck!
97 GMC, 2002 LS6.
1991 GMC Syclone #1428
ridnlow...Any new progress you'd like to share?Gar
i can't wait to be diong what your doing? nice work. what did you do for the motor mounts
Motor is in..we got kind of impatient and didnt paint, so we may pull it again and paint it, just trying to get it running for now.. Got the notice that Allen shipped out my harness today so that should be in... Ill be sure to take some picture of the harness and the process of putting it on..
Skates on the motor mounts, we went with S & P.. had to do a little work to get it to go but wasnt to bad..
