Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: Whipple intercooler, part 9
    San Antonio, TX
    HI,
    Don't worry about it spraying on the iat, it's coated and sure it will read lower if it actually saturates it, but it really doesn't, it's a fog of air, if that, it evaporates quickly.
    But yes, it can saturate it and can make it read low.
    As an example, under good air, I run 19degs on my 5.3L with 5psi with the intercooler, the meth does a bit better, so 8psi should be ok around 18-24degs of timing, depending on the truck.
    Now that you have an '02 PCM, I bet we get some good timing out of it and the iat's start to show good readings with the grommet it in and relocated.
    How much boost is your truck going to produce? Is it just the intercooler, no meth?
    I'd say let's start out with 18psi with 5-7psi.
    hurry up, heheh!
    allen
    Dec 2005
    Chicago-ish
    No meth, that's why the X-large intercooler. I put a 7.5" crank pulley in place of the 6.5". With the driven pulley that I was using to make 6 psi, I think it would have made 9 psi without the intercooler, so if the intercooler lowers the pressure by 1-2 lbs, it should be in the 7 psi neighborhood.
    2000 Sierra 2500 HD. 408 (11-2007) Whipplecharged, Big (18x24x4) FMIC.
    <div class='quotetop'>QUOTE(MikeGyver &#064; Jun 1 2006, 09&#58;05 PM) [snapback]54512[/snapback]</div>
    No meth, that&#39;s why the X-large intercooler. I put a 7.5" crank pulley in place of the 6.5". With the driven pulley that I was using to make 6 psi, I think it would have made 9 psi without the intercooler, so if the intercooler lowers the pressure by 1-2 lbs, it should be in the 7 psi neighborhood.
    Hi,
    Is this the same truck in the picture on ebay?
    This is the ebay link:
    http://cgi.ebay.com/ebaymotors/ws/eBayISAP...dget,osi_widget
    alos how well did this intercooler work for the whipple. I have had dreams of doing a similar project but with changing the intake and using a intakeelbows.com elbow and edelbrock intake.
    Thanks
    Jake
