Page 2 of 2 FirstFirst 1 2
Results 11 to 16 of 16
Thread: wideband in and working!
  1. #11
    Sep 2004
    Breaux Bridge, LA
    thanks for the info chris. i don't know too much about this, so i'll relay the message to my friend.
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    10.35@130 pump gas LQ4
    Knothead Racing
  2. #12
    Apr 2003
    DFCO??
    Andrew
    2001 Silverado 6.0 RCLB - Home Page - 4.8 to 6.0 Swap
    Nelson Tune, Comp Cam XR265HR, Pacesetters, Hotchkis Sways, 3.42, Eaton Posi, Transgo, LS1 Fans, Magnaflow, Eagle 219's 18x9.5, Fold-a-cover
  3. #13
    <div class='quotetop'>QUOTE(bluecajun5.3 &#064; Mar 30 2006, 04&#58;00 PM) [snapback]48784[/snapback]</div>
    hey chris, what&#39;s this i hear about the ground offset. i might be having those problems. my friend fabed up his new lc1 to where he could take it from car to car for quick tuning. he has a 98 z28 so the electical connector he put on the lc1 is a male so that it can connect to the female connector on the car. (but the trucks are opposite) so what we went ahead and did was connected two female connectors togeter so that it could hook up to the male connector that&#39;s on my truck. hooked it up to the truck and kept getting heater stuck open message. (using efi live). so we tried it on his car, and what do you know the freaking thing works. we double checked the two female connectors we fabed up and still nothing. any ideas on what could be the problem. thanks for your help... lance
    I dont know if im reading this right, But your talking about your lc-1 handling narrowband duties, witch works on your friends z28 but not on your truck? If so the problem is the sens wire and the ground are not the same. I dont remember the color off the top of my head but you will need a volt meter to find out witch wire reads around 0.45 volts when the engine is warm, hook the yellow wire to that. The ground wire can be found by a simple Ohms test as it will have less than 1 Ohm with the engine off. Wire that directly into the IEO interface or to the heater ground. If your getting a heater code you can find the 12V wire with the Volt meter and run it to your old 02 sensor, No need to have it in the exhaust just run it too it and tie it up somwhere. The LC-1 is a real POS Im surprised it has not fried yet trying to get it to work on your truck. Dont hold me liable if it takes a crap. This thing is a real POS&#33; I suggest a AEM or a PLX device if you have the cheese for it.
  4. #14
    Sep 2004
    Breaux Bridge, LA
    <div class='quotetop'>QUOTE(Tyson &#064; Apr 25 2006, 10&#58;56 PM) [snapback]51235[/snapback]</div>
    thank you for the information tyson. that sounds like a very good explanation for the malfunction. i&#39;ll send this to my friend and have him read up on this. like i said before, i don&#39;t know jack about this kind of stuff.
    11' Sierra 6.2 NHT
    14.46@91 Stock
    89' Mustang LSX
    Knothead Racing
  5. #15
    Jan 2006
    Mine is after the turbo per Allen.
    Jamest<div class='quotetop'>QUOTE(Turborado &#064; Mar 30 2006, 06&#58;31 PM) [snapback]48791[/snapback]</div>
    What brand of wideband are you using? I want to get one pretty soon&#33; I know allen sells an AEM. Anyone with STS are you installing your wideband after the cats but before the turbo, or after the turbo? Thanks
    12 Sec. Club! SOLD
    SOLD***
  6. #16
    San Marcos Texas
    AEM. After the turbo. No cats&#33;
