Page 2 of 2 FirstFirst 1 2
Results 11 to 12 of 12
Thread: Fuel Gauge
  1. #11
    Jun 2007
    tulsa, oklahoma
    my guage does the same thing, using 02 cluster, but 83 sending unit, it is because the newer tanks use a 33 -240 ohm sending unit, older one uses a 0-90 ohms, your sending unit is prob. a 0-90 ohms
    1987 jeep wrangler, 1999 LS 1, 4l60 231j transfercase, dana 30 frontend ford 8.8 rearend 3:73 gear ratio. sandersons shortie headers, 2.25 inch exhaust into 3 inch flowmaster muffler.
  2. #12
    Jun 2007
    maine
    Quote Originally Posted by Time2Kill View Post
    What are you guys doing with the fuel gauge? I have a '98 1500, and the old PCM had a fuel gauge output wire on it, but the new PCM ('02 1500) transfers the fuel guage signal across the Class 2 Serial Data. Is there anywhere I can run the fuel gauge wire to so it can pickup the signal for fuel level?
    well thats a scary thought wonder if ill have the same problem with my 5.3 swap. if i have nelson redo the wiring harness i hope that should take care of it.
