Page 2 of 2 FirstFirst 1 2
Results 11 to 14 of 14
Thread: Ok guys,I need a 6.0
  1. #11
    Sep 2003
    Yeah I think I am goin with a 383 ZZ3 short block with bowtie vortec heads,ARP rod bolts,already comes with a 4340 forged steel crank and gonna go with forged pistons,not sure which ones yet,I think I know but gonna do more research.
  2. #12
    Nov 2005
    ohio
    <div class='quotetop'>QUOTE(vortec350 &#064; Feb 11 2006, 06&#58;11 PM) [snapback]44235[/snapback]</div>
    that&#39;s gonna be bad ass, my buddies 78 chevy 3/4 ton 4x4 has a carbed 383 stroker and that truck beats 5.0 mustangs, your gonna fly in yours , mmmmmmmm RAMJET,mmmmmmmm&#33;&#33;&#33;&#33;
  3. #13
    Sep 2003
    Yeah been wanting a ramjet for along time but I will do it on the new motor.
  4. #14
    May 2004
    One bad Mofo&#33; This used to be my dream motor. I would go with Ross forged if you ask me, they are well worth the money.
    Displacement: 383 ci Bore x Stroke: 4.00” x 3.80”
    Block: 88962516 Four bolt main, cast iron Firing Order: 1-8-4-3-6-5-7-2
    Con. Rods: 12497624 PM 5.7” PM Steel Rocker Arms: 12370838 1.5 ratio roller rockers kit
    Pistons: 12499103 High Silicon Aluminum, .005 O/S Piston Rings: 12499107 .005 O/S
    Camshaft: 12370846 Lift: 0.509” I, 0.528” E
    Duration: 222° I, 230° E @ .050” Lift Centerline: 112°
    Valve Lash: Zero Timing Chain: 14088783 8 mm single roller design.
    Cylinder Heads: 12464289 Fast Burn Volume: 62 cc
    Head Gasket: 10105117 (.028” compressed thickness)
    Intake Valves: 12555331, 2.00” dia. Exhaust Valves: 12551313, 1.55” dia.
    Valve Springs: 12551483 Oil Pan: 5 quart with new filter.
    Oil Pres. (norm): 40 psi @ 2,000 RPM Oil Filter: UPF1218 ACDelco Ultra Gold
    Spark Plugs: R44LTS or R42LTS for racing Fuel: Premium 92 Octane or greater
    Partial Engine: 12499106 Damper: 12498008
    Crankshaft: 12489436 4340 steel alloy (forged), one piece rear seal design, 3.8” stroke, 2.45 main journals/ 2.10” rod journals (standard 350 engine), main and rod journals are fully radiused, number 1 & 4 crank pins hollowed, cross drill oiling, rod and main oil chamfered, 3.00” flange bolt circle, nitride treated, and main bearing bolt torque.
    Intake Manifold: None supplied with this crate engine.
    Water Pump: None supplied with this crate engine.
    Ignition Timing: 32° total @ 3000 RPM with vacuum advance disconnected.
    Flexplate: 14088765 12-3/4” outside diameter, 153 tooth, 10.75” bolt pattern.
    Technical Notes: 1 - GM recommends a Demon 750 CFM or Holley 750 CFM carburetor for ZZ383 applications.
    2 - In 2004 GM redesigned the pistons and rings and they are .005" over sized now. This was done to better improve piston to cylinder wall clearance. The .005” O/S pistons and rings are the recommended standard size for all second design 383 ci engines. The first design ring and piston sets were: [Rings - 12522848 std. 4.00”, Pistons - 12489437 std. 4.00" (piston & pin set).]
    NoteΉ: The GMPP catalog states that the compression ratio is 9.1:1 which is wrong. The compression ratio is 9.7:1 for the ZZ383/425 where the compression ratio is 9.1:1 for that HT 383 which uses a thicker head gasket.
    97 GMC, 2002 LS6.
    1991 GMC Syclone #1428
