Page 2 of 2 FirstFirst 1 2
Results 11 to 20 of 29
Thread: 92 pickup 6.0 factory computer
    May 2011
    i need help with my clutch. im having issues with it not engaging the flywheel. I bought the sachs nfw1050 flywheel from rock auto for the 6.0l. now my trans is a nv4500 from a 97ish diesel Chevrolet. the clutch is a south bend single disc. my throwout bearing is internal. now the first time I mated them up didn't really notice anything wrong. then decided to pull the trans to put in the steel braded clutch line. the end of my throw out bearing tube had contacted my clutch disc. so I bought a new one and measured them. thinking that it was just my south bend clutch may be a little thicker I shaved less than .25" off the end of the tube. put it all back together but now with my foot off the clutch and it in gear it feels like your riding the clutch and slipping it. put it in gear and push the truck you can see and hear the clutch disc spinning.
    now did I order the correct flywheel? or is it too thick causing my clutch to be too close to the trans? or do I have other issues?
    Dec 2008
    South Carolina
    Did you use a spacer?
    2008 GMC Sierra SLE....370ci LY6 with some goodies SOLD
    1995 C2500- LS1 swap with a mp112
    build thread- http://www.ls1truck.com/forums/lsx-t...-ls1-swap.html
    May 2011
    Found a flywheel in cali that is "suppose" to be for a 2000 truck. They said it is not for the 01 and later. Got it bought today will see when it comes in.
