Results 11 to 20 of 21
Thread: Need block suggestions! Having issues
Threaded View
    Mar 2013
    Edmonton, AB, Canada
    Engine specs as of last build:
    -Thompson Motorsports 5.7l (Refurbished seasoned 5.3l)
    -72mm Magnum turbo
    -TU1 Custom Grind cam(spec speed.inc)
    -799 heads
    -GM MLS head gaskets
    -ARP head bolts
    -.660" Trick Flow dual valve springs
    -Titanium retainers & locks
    -7.400" Comp Cams Chromoly Push Rods
    -LS7 lifters
    -5.3l(LM7) rockers
    -Forged Probe Pistons 3.902" flat top
    -TMS Moly rings
    -4340 Forged scat I-beam connecting rod w/ ARP 8740 rod bolts
    -King racing bearings
    -Melling high pressure relief oil pump
    -TR6 spark plugs
    -"Muscle Car" oil pan
    -All other parts are stk 5.3l(LM7)
    So here's the story:
    Block #1: 5.3l out of a 120,000km 2001 Silverado
    Get on the dyno and after several weak pulls it starts venting bad. Pull the head Cylinder number 5 had a broken piston. After further inspection multiple pistons had cracks between the ring slots.
    Block #2:Thompson Motorsports 5.7l(bored from 5.3l) engine(The one described at the top of this post)
    Runs for about 15min while on the highway. I started accelerating going 130kmh with 5lb of boost. Engine locks up and wont turn over. Pull the block out- 3 cylinders cracked to the waterjacket, pistons are wedged in cylinder bore, and most of the rods are bent.(no damage on the gaskets or the head really, although the heads show signs of detonation.
    Block #3: Get warranty Thompson Motorsports 5.7l(bored from 5.3l) engine back
    Tried installing cam but it was very tight. Turns out the cam was bent from the last engine blowing up. Decide to get the whole thing gone through. Fix the cam, but the sonic test determines that the cylinder walls in some spots are .140". After doing some research a lot of people say it's ok for NA but not for boost(i plan on going up to 18lb).
    Additional info: Most parts have been reused several times now. I have used new head gaskets every time and got new head bolts as well.
    So: I have the first block still with some scoring in the cylinders and a freshly sandblasted lq4. What do you guys recommend I do? I am willing to buy a different block if need be, but if either of these could be used I would like to go that route.
    Any help would be greatly appreciated!
    I can post pictures if need be
    Back Alley Motorsports 98 GMC
    -5.3l LM7 bored to 5.7l Thompson Motorsports -72mm T4 Magnum Turbo
    -TU1 Custom Grind cam(spec speed.inc) -799 heads
    -.660" Trick Flow dual valve springs -Forged Probe Pistons 3.902" flat top
