Page 2 of 2 FirstFirst 1 2
Results 11 to 13 of 13
Thread: 160º T-stat harmful?
  1. #11
    Jul 2005
    modesto, ca
    Horse power = heat new engines make more power per cube which = higher oil temps regardless of coolant temp. oil temp is effected buy coolant temp but its not as much as older engines and not as much as people think. Ihave a '66 chevy with a 383 stroker with 160 stat and the coolant temp runs at 175 to 185. before I had an oul cooler the oil temp would get up to 250 now with a cooler it sets around 200 to 215 depends on how har I beat on it.
    http://i10.photobucket.com/albums/a1...dited-copy.jpg
    2007 Sierra crew 5.3 4wd, stock for now
    2004 Sierra scsb 5.3 - sold
    02 Z28 SLP cold air pack, Corsa exh, Center Force dual friction + 23 lb flywheel
    66 Chevy C20 (collecting dust)
  2. #12
    Jun 2005
    Cumming, GA
    Hey, what did (does) it take to build a SBC 383? Is it a 350 block with a 400 crank? I can't remember. I know the 6.0 in the trucks, corvette and GTO is a 383, but that's not at all what I am talking about here
    2002 ECSB, Nelson Tune, LS1 electric fans, 145A alternator, K&N FIPK, 160º T-stat, TB coolant bypass, Corvette servo, 4 headlight mod, blue LED gauge cluster
  3. #13
    Jul 2005
    modesto, ca
    I have a 6.0 L block bored .060 over and a crank with a 3.7 inch stroke. Gen I & II engines is a 350 block bored .030 over and a 400 crank @3.75 inch stroke.
